Need software to tract stages???
We are a mfg of plastic packaging, and would like to have a system that allows users to group doucments together in one folder and allow that folder to be moved along a process.  Visually we see it as a series of folders that represent each stage in the process... projects are then grouped into a folder of thier own and can be moved along the process folders.
Is there any software that does something like this?  Or can anyone offer ideas about how we can effectivly manage the process flow and document control/grouping?
RE: Need software to tract stages???
You can either have someone write you the SW to custom fit what you need or you can find some off the shelf stuff, but by the time you customize you could have written it and have a better product. I would suggest using VB with access if it is small amount of data. SQL is the next step up. I would not suggest VB if this is going to be on the web. You might try Java. Hope this helps.
