material search
material search
I am looking for .032 DIA TYPE 304 CORROSION RESISTANT STEEL SPRING WIRE, which meets ASTM A313 that is supplied in lengths, not coils or spools?
RE: material search
RE: material search
http://www.malinco.com/industrial/index.html
http://www.calfinewire.com/index.asp
I especially like to work with Malin’s recreational wire.
RE: material search
nationalstandard.com
bekaert.com
gibbswire.com
branfordwire.com
Cut and straightened is not common in this size. Most spring formers work from coil. You should be able to get some but the minimum order quantity may be larger than for coil.
Corrosion never sleeps, but it can be managed.
http://www.trenttube.com/Trent/tech_form.htm
