Rotary Gear Flow Divider
I am looking at purchasing a Rotary Gear type hydraulic flow divider. My limited research has indicated that you get what you pay for with these products. With that in mind, I am looking for a very high quality Rotary Gear type flow divider. I have located a few suppliers, but I don't have any way of knowing if they are good quality products or not.
If you know of a source for a good quality rotary gear flow divider I would like to hear from you.
Thank you in advance.
Nilcram
Nilcram
RE: Rotary Gear Flow Divider
The level of accuracy you need when synchronising cylinders dictates the flow divider that is used.
In my personal experience...the bottom end of the range is the unit from Delta Power. These units are generally more competitively priced and give an accuracy of around 90%.
Next come the unit from Slack and Parr. The prices of these untis is 70%-80% higher than the Delta Power unit. For your money you get a flow divider that is upto 99.5% efficient.
Finally...I have used a Bucher flow divider for a U.S Navy application. The unit is very expensive...however it is only slightly more efficient than the Slack and Parr unit.
Remember...when selecting a flow divider...drive it as fast as possible. The faster they run , the more efficient they are.
Hydromech.
Again, thank you for your help.
Nilcram
"FIEROWISEGUY"
http:/
fIEROWISEGUY (Industrial) 25 Feb 05 18:15
Is there any reason not to consider a valve type flow divider?
The main reason is valve type flow divifers are energy wasters since they are restricters, and even more so when the actuators are unevenly loaded.
On uneven loads pressure at the inlet of a valve type flow divider is equal to the highest outlet pressure. A motor flow dividers inlet pressure is the avearge of the sum of the outlet pressure.
Bud Trinkel CFPE
HYDRA-PNEU CONSULTING, INC.
fluidpower1 @ hotmail.com
http://www.fluidpower1.us
Basically, spool dividers throttle the lowest loads to drive their emergy demand up to equal the highest load. They force the pump to supply the highest energy, then throttle the excess to heat.
Rotary dividers transfer excess energy from the light circuits to the heavy circuits, without throttling and withminimal losses.
I second bud's comments, they are energy wasters. Usually picked due to low OEM cost in specific applications.
kcj
