Minimum allowable Carbon content for ASTM A105 material
ASTM specifies 0.35% as the maximum carbon content for A105 material. No minimum limit has been specified. My client has asked for A105 forgings and also specified that C<0.25%. My question is whether it is possible to fulfill both A105 and C<0.25%?
V.V.vipin
V.V.vipin
RE: Minimum allowable Carbon content for ASTM A105 material
prex
motori@xcalcsREMOVE.com
http://www.xcalcs.com
Online tools for structural design
Minimum carbon requirements are probably governed by other parameters dictated in ASTM A105.
If carbon content is too low, the required yield strength and/or ductility requirements of the ASTM Spec will not be met ?
Any metalurgists out there with a response ?
MJC
European pressure vessel standards restric carbon content to a maximum of 0.25%.
Have fun
www.gowelding.com
