Mold Flow Analysis
Mold Flow Analysis
Mold Flow Analysis
Any suggestions on mold flow analysis software, either integrated with SW or separate?
A
RE: Mold Flow Analysis
integrated with 2005
Chris
Sr. Mechanical Designer, CAD
SolidWorks 2005 SP0.1
It depends on how complex is your model and mold. The analysis integated in SW is only useful for simple models and molds (for example, you only have one injection point available).
Mold flow in SW is to a separeted package like Comos Express is to CosmosWorks.
Solidworks 2005 Does anyone use the SW method to create mold core and cavity using parting lines and parting surfaces? I design complex plastic injection molds and have never been able to make this work well. Is it just me?
I often use my own methods, although the shut-off feature for holes is very handy even for complex parting lines and features.  I can ellaborate later, if necessary, but the tools available in 05 are much stronger than before.
I make cores, cavities, and pulls all the time for very complex geometry and have been doing so since 1999.  So it could be done even then, but not necessarily by using the "mold tools".
Jeff Mowry
www.industrialdesignhaus.com
Reality is no respecter of good intentions.
Moldflow Express in SW 2005 doesn't seem to indicate things like areas of likely sink marks, weld line issues, nor issues relating to warpage.
I was more curious as to what software people use that takes these things into account.
A
