BOM to match Balloons
Hello everyone,
Due to cost restrictions my company is using 2001+ to do all there models and drawings.
The problem I am having is that I have an assembly with the three different configurations listed below:
Configuration A= Assembly exploded with detail parts suppressed.
Configuration B= Detail assembly 1 with main parts of assembly suppressed and detail parts of config "C" suppressed.
Configuration C= Detail assembly 2 with main parts of assembly suppressed and detail parts of config "B"suppressed.
On sheet 1 I have assembly "A" exploded and have the BOM generated from that view. It only shows the main parts of the assembly and will not show the rest of the components in the tree.
On sheet 2 I have both configurations of "B" and "C" detailed out with balloons and detail views of each. It appears that each configuration sees only the parts that are resolved in the tree.
What I want to accomplish is to have the BOM on sheet 1 with all components listed. And have the balloons on sheet 2 match the BOM on sheet 1. Is there something I am missing. I know with future releases of solidworks I have not had a problem with this. Any help one may be able offer me would be greatly appreciated.
Best Regards,
Jon
Challenges are what makes life interesting; overcoming them is what makes life meaningful.
RE: BOM to match Balloons
If you want the parts to show on the bom just hide the parts that you dont want to see in the configuration. That make the bom show the parts not shown show up in 2003 anyway.
Roger
Any other suggestions. I think I have been through the obvious ones.
Best Regards,
Jon
Do not hide the parts in the assembly you do not want shown on the drawing. Do this in the tree of the drawing itself. This way if someone does a “show all” in the assembly model, it will not change your drawing.
Good luck, I have worked for companies that lost more money “trying to save money”. The bean counters do not realize the money they save upfront cost big time in the end.
Bradley
I do not see the option "Use custom property values from model shown" Do I have to Ctrl select the view and sheet. I'm using 2001+ just as a reminder.
The thing is I already have all my views laid out and do not want to spend the time re-doing all the views if I don't have to. I really miss working with the future versions of solidworks. I guess I will just have to settle with what i have and create seperate BOM's for each configuration shown on page 2. Although I would like to find another way.
Best Regards,
Jon
The box is there, find the one that has the name of all your views. Have you inserted a view of the one you want a BOM of? What we did and still do is have the whole assembly as a view off the sheet. That way it will not print. No need to change what you have.
Bradley
I found it. Thanks Bradley. A star for you!
Just needed to wipe the sleepers out of my eyes to see it. I figured it was something simplistic. I have found it very hard to get used to 2005 SW and have to go back to 2001+ to figure out how it was done the old way.
Best Regards,
Jon
For somereason I cannot give you a star. The company i work for has alot of internet restrictions. I will try to give you a star when I get back on my home system.
Thanks again for the post!
Best Regards,
Jon
How do I fix the balloon numbering sequence.
Best Regards,
Jon
Just had a thought. Delete any BOM’s on sheet 2. You may have to delete it in the tree. Reinsert the BOM using your new view of the full assembly. Now does the balloons match?
Bradley
Best Regards,
Jon
Best Regards,
Jon
Components that are suppressed will not show on BOM. Components that are hidden will show on BOM.
Insert on sheet 2, the same assembly view that is the view on sheet one that is giving you your BOM. Move this view of the sheet. Now click that new view you put in and insert a BOM. If you do not want that BOM showing on your drawing, then hide it. But it does need to be there. You can also hide this extra view you just added.
Bradley
