Hydraulic pump
Hydraulic pump
Hydraulic pump
I need a pump that can deliver a continuous flow of salt water (flow rate = about 1 litre/min) at high pressure (400 bar minimum). I have tried using a air/hydraulic intensifier type pump but it needs to recharge every second or so thus interrupting the flow to the extent that the pressure drops off during recharge. Can anyone suggest an economical way of achieving continuous flow. The unit is to be used in a laboratory so portability and noise are a concern.
RE: Hydraulic pump
Post this question to Mechanical Engineering -Piping and Fluid Mechanics -much more traffic there.
Note: "Fluid Power" in this group means very high OIL (usually)pressure (1000 -10,000 psi)mechanical energy systems-pumps-cylinders etc.
