Heat Treating Parameter
If I recall correctly, the the Larson-Miller parameter for creep, defined as
P = T(20+log t), where T is abs. Temp & t is hours,
can be used for time/Temperature substitution for heat treating of steels. I have a boiler tube (centerwall, max design metal temp 850 F) that may have experienced temperatures in excess of 1000 F for 3 years. I also have a piece of the same tube batch that never went into service. My question is this: would a piece of this tube placed in a furnace at 1200 F for 24 be expected to experience the same degree of microstructural degradation as the tubes in service at 1000 F for 25,500 hours? The LMP indicates yes, but it would be nice to get some other opinions.
RE: Heat Treating Parameter
For some experimental justification of the approach I would recommend "The Influence of Stress Relief on the Properties of C and C-Mn Pressure Vessel Steel Plates" by Gulvin, Scott, Haddrill and Glen. published in Journal of the West of Scotland Iron and Steel Institute Vol 80, 1972-1973
To simulate microstructural degradation, EPRI had used elevated temperature exposure and selected stress levels to evaluate spheroidization damage, which was ultimately tied to remaining creep life using LMP.
I would recommend you purchase this especially if you routinely conduct boiler tube failures. The report number is TR-102433 V-1 and V-2
