hole wizard leader/text gap?
Is there any way to change the gap between the end of a leader and the leader text when using hole wizard callouts? The gap is unusually large.
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: hole wizard leader/text gap?
the actual text of the note read as such:
<NUM_INST>X <MOD-DIAM> <hw-diam> <hw-thru> <dim>
What is the <dim> for at the end? Removing it solves the problem, but why is it there? The calloutformat.txt file appears to be correct...
SW 2005 0.1
