Animator Help
Animator Help
Animator Help
New to animator and physical dynamics.
I would like to show a rotating shaft and a non-rotating nut moving linearly on the shaft axis.  Been able to set this up in physical dynamics with a rotary motor and a linear motor, but the scaling is brutal.
Set the velocity of the shaft to maximum and the nut to minimum.  After 1 turn of the shaft the nut travels the full length.
I'm running SW2004 SP4.2.  Any help would be appreciated.
TIA
Every day is painful ... and the last one kills you.
