Interlock Insulated Panels
Has anybody worked with these panels? Please give me your thoughts about them. http://www.iipinc.com/
RE: Interlock Insulated Panels
Hi Samo
What kind of info are you looking for on the Interlock Insulated Panels?  I can answer most for you easily.  The R factor is unbelievable!! The construction process is very simple and fast.  Be specific, I'll assist where I can.
Ices
Hi Samo
I just wanted to add one more note.  I am NOT an engineer, I work at Interlock Insulated Panels Inc.  which is the first plant in production to make these Structural Steel Insulated Panels.  Regardless, I'll still give you whatever I can to answer your questions.
Ices
