"Inputdlg" doesn't work. Is it OS X compatible?
I get the following error message whenever I use the inputdlg command (i.e.
answer=inputdlg(prompt) ):
??? Error using ==> isvarname
Attempt to execute SCRIPT namelengthmax as a function.
Error in ==> guihandles>createHandles at 96
if ~isempty(tag) & isvarname(tag) % can it be used as a fieldname?
Error in ==> guihandles at 75
handles = createHandles(fig);
Error in ==> inputdlg at 303
handles = guihandles(InputFig);
Does anybody know if this is an os x problem? Any help would be greatly appreciated!
RE: "Inputdlg" doesn't work. Is it OS X compatible?
prompt='hallo'
Works in w2k from the command line
does it work from the command line rather than a script?
Cheers
Greg Locock
