Battered Piles working in Tension and Compression
I am designing a 7 story concrete building. Lateral system: shear walls. Foundations: Micropiles. I have huge lateral loads on this structure because: 1. I am holding back 20' of earth on two sides (non-opposite sides). 2. The structure is highly irregular and stiff (high seismic loads).
I want to use battered piles to resist the lateral loads under the shear walls. My geotech report says that I can use the horizontal component of the pile's axial capacity to resist lateral loads. Would it be more correct to use the horizontal componant of the axial load that is actually acting on the pile at the time of the shear load as resistance for the lateral?
Also, the piles can be designed to resist about half of their axial capacity in tension. If i batter the piles away from the direction of the shear, can i use the pile in tension (once vertical loads have been overcome) to resist the lateral loads. Wouldn't it be more efficient to batter the piles in this way (tension) because then the vertical loads on the pile are actually off-setting the tension imposed by the lateral loads?
Thank you for your help.
RE: Battered Piles working in Tension and Compression
Qshake
Eng-Tips Forums:Real Solutions for Real Problems Really Quick.
Please see FAQ731-376 for great suggestions on how to make the best use of Eng-Tips Fora. See FAQ158-922 for recommendations regarding the question, "How Do You Evaluate Fill Settlement Beneath Structures?"
it can be harmful. You decide to fight agains a nature forces, not just follow it.
Remember strong tree are easy to fall against the strong wind than the skinny tree.
Battered pile in bridges is not to counter full effect of earthquake.
Why dont you solve the opposites building walls with ground achored sheet pile...?
