When no tolerance on hole size is called out
I have a hole callout of .097 dia. with a .002 tp at mmc. Since there is no specific tolerance on the hole size, is it standard practice to use the +/-.005 tolerance in the tolerance block for the drawing? My understanding was that on holes with no tolerance specified fell under some sort of spec where I believe the tolerance for a hole of this size is +.003/-.001 If any one can point me to a spec that shows this, it would be of great help
RE: When no tolerance on hole size is called out
Chris
Sr. Mechanical Designer, CAD
SolidWorks 2005 SP0.1
So, unless the dimension is max, min, basic or stock, or there is a general note specifying the tolerance application, it MUST default to the title block tolerance.
ringman, can you cite the ASME standard that says a hole must have a tolerance on size? Why would a hole be different than any of feature of form?
"I think there is a world market for maybe five computers."
Thomas Watson, chairman of IBM, 1943.
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
