Running Pro/e without graphic display
We have Wildfire and generate BOM and very large assemblies. It seems that is possible to switch off graphic display and graphic generation in order to have faster response. Does someone know how ...
RE: Running Pro/e without graphic display
Use spaces between the 4 as shown in example below.
startup_command run_mode graphics_mode 1 trail_name.txt
wildfire.bat 1 0 1 bom_trail.txt
the command may run without the .bat or .exe depending on your computer settings
1 is the default run mode
0 is selects no graphics be displayed
1 the second 1 is used to tell Pro/E you want to run a trail
Graphics modes
0 No Graphics
7 Open GL
8 X-Windows
9 Win_GDI
Give it a shot and let me know if it works!
If it does you'd just need to have a txt document with Assembly or Drawing name to open like draw01.drw, draw2.drw that you could replace and save to a new trail file.
You should be able to put multiple names in the trail file and run trails with simultaneous copies of the lines from your original trail.
Michael
