Sheet Format/Size - popup window!
Whenever i modify the core "Drawing.drwdot" (to change arrow sizes, fonts, etc), and save it back to the Drawing Template file, i always loose the Popup "Sheet Format/Size" window everytime i want to create a new drawing. Is there a setting somewhere that turns this window back on???
PJ
PJ
RE: Sheet Format/Size - popup window!
Scott Baugh, CSWP
3DVision Technologies
www.3dvisiontech.com
www.scottjbaugh.com
FAQ731-376
FAQ559-716 - SW Fora Users
What about opening up a new part file and selecting what plane to start on automaticly, is that option available?
PJ.
If you toggle under Tools\options\System options\Sketch "Create sketch on new part" that will start a sketch on the front plane. You cannot control which plane in which to start the sketch on.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Grtz,
Bouke
