LIST OF COMMANDS
LIST OF COMMANDS
LIST OF COMMANDS
DOES ANYONE KNOW WHERE I CAN GET A LIST OF ABBREVIATED COMMANDS LIKE TR FOR TRIM AND M FOR MOVE
RE: LIST OF COMMANDS
search for file acad.pgp in your autocad folder. Open in notepad.
"Everybody is ignorant, only on different subjects." — Will Rogers
...or if have the Express Tools 1-9, You can use "aliasedit"
Tutorial
L.
ADT 2004
ACAD 2002
If you have 2005, you can get there by Tools, Customize, Edit Custom Files, Program Parameters (autocad pgp).
You can also edit them to make them what you prefer.  For example, co is copy, which I use a lot, but requires both hands to type. C is circle, which I use less often, but only takes one key stroke.  I changed c to copy and circle to cc.
Remember: The Chinese ideogram for “crisis” is comprised of the characters for “danger” and “opportunity.”
-Steve
bigplc -
Command aliases can be found in the acad.pgp file and also the acad.lsp file.  As others have mentioned there are many ways to access these ASCII files, from within Autocad as well as using external text editors.  If you are interested, you can read these files to learn the syntax of the methods (which are different within each file) and then make your own.  I use I, S, C, E, Q, P, T and N as single letter commands to change OSNAPS, EC for End and Center OSNAPS, EQ for End and QUandrand OSNAPS, L for line, CI for circle, Z for Zoom, ZE for Zoom Extents and zillions more, of varying complexity.
Command aliases
Commands Aliases
3DARRAY 3a
3DFACE 3f
3DORBIT 3do
3DPOLY 3p
ADCENTER adc
ALIGN al
APPLOAD ap
ARC a
AREA aa
ARRAY ar
ATTDEF att, ddattdef
-ATTDEF -att
ATTEDIT ate
-ATTEDIT -ate, atte
ATTEXT ddattext
BHATCH h, bh
BLOCK b
-BLOCK -b
BOUNDARY bo
-BOUNDARY -bo
BREAK br
CHAMFER cha
CHANGE -ch
CIRCLE c
COLOR col, colour, ddcolor
COPY co, cp
DBCONNECT aad, aex, ali, asq, aro, ase,
dbc
DDEDIT ed
DDVPOINT vp
DIMALIGNED dal, dimali
DIMANGULAR dan, dimang
DIMBASELINE dba, dimbase
DIMCENTER dce
DIMCONTINUE dco, dimcont
DIMDIAMETER ddi, dimdia
DIMEDIT ded, dimed
DIMLINEAR dli, dimlin
DIMORDINATE dor, dimord
DIMOVERRIDE dov, dimover
DIMRADIUS dra, dimrad
DIMSTYLE d, ddim, dst, dimsty
DIMTEDIT dimted
DIST di
DIVIDE div
DONUT do
DRAWORDER dr
DSETTINGS ds, ddrmodes, rm, se
DSVIEWER av
DVIEW dv
ELLIPSE el
ERASE e
EXPLODE x
EXPORT exp
EXTEND ex
EXTRUDE ext
FILLET f
FILTER fi
GROUP g
-GROUP -g
HATCH -h
HATCHEDIT he
HIDE hi
IMAGE im
-IMAGE -im
IMAGEADJUST iad
IMAGEATTACH iat
IMAGECLIP icl
IMPORT imp
INSERT ddinsert, i
-INSERT -i
INTERFERE inf
INTERSECT in
INSERTOBJ io
LAYER ddlmodes, la
-LAYER -la
-LAYOUT lo
LEADER lead
LENGTHEN len
LINE l
LINETYPE lt, ltype, ddltype
-LINETYPE -lt, -ltype
LIST li, ls
LTSCALE lts
LWEIGHT lw, lineweight
MATCHPROP ma
MEASURE me
MIRROR mi
MLINE ml
MOVE m
MSPACE ms
MTEXT t, mt
-MTEXT -t
MVIEW mv
OFFSET o
OPTIONS ddgrips, gr, op, pr
OSNAP ddosnap, os
-OSNAP -os
PAN p
-PAN -p
PASTESPEC pa
PEDIT pe
PLINE pl
PLOT print
POINT po
POLYGON pol
PREVIEW pre
PROPERTIES ch, ddchprop, ddmodify,
mo, props
PROPERTIESCLOSE prclose
PSPACE ps
PURGE pu
QLEADER le
QUIT exit
RECTANG rec
REDRAW r
REDRAWALL ra
REGEN re
REGENALL rea
REGION reg
RENAME ren
-RENAME -ren
RENDER rr
REVOLVE rev
RPREF rpr
ROTATE ro
SCALE sc
SCRIPT scr
SECTION sec
SETVAR set
SLICE sl
SNAP sn
SOLID so
SPELL sp
SPLINE spl
SPLINEDIT spe
STRETCH s
STYLE st
SUBTRACT su
TABLET ta
THICKNESS th
TILEMODE ti, tm
TOLERANCE tol
TOOLBAR to
TORUS tor
TRIM tr
UNION uni
UNITS un, ddunits
-UNITS -un
VIEW ddview, v
-VIEW -v
VPOINT -vp
WBLOCK w
-WBLOCK -w
WEDGE we
XATTACH xa
XBIND xb
-XBIND -xb
XCLIP xc
XLINE xl
XREF xr
-XREF -xr
ZOOM z
I have that list in my files.  I don't remember if that's from a web page or in the AutoCAD help file but either way it's a list of keyboard shortcuts.
