LPT port in VB 5
LPT port in VB 5
Hi !
How can read a lpt port ? I have a motorola 68hc912xxx programer connected to a pc ( rs232 -> adapter to lpt port),
and i need to 'see' the lpt? how can i do that in Vb, Mscomm does not support the plt , am i right? Any hint ?
I'm a newbee ..so sorry if the question seems stupid.
Thanx for your answers.
RE: LPT port in VB 5
Parallel Port Complete book has an accompaning disk with 2 dll's one for 16 bit applications and one for 32 bit application which will do exactly this function for you, also it has ready code to use in vb5 to monitor your parallel port.I wonder if you can download them from their website.
Please note that since the 1st PC model, parallel port was re-designed 3 times, i.e. we have 3 different modes of operation for any new pc parallel port, the older did not support bi direction so you can not read it, so actually those code test your port, set the proper mode for communication, and then monitor or do what you want..
Any more help, I will be glad
