DOWNCOMER CHOKE FLOODING
I am evaluating the performance of a distillation column for a revamp.
I don't know what's the maximum allowable velocity of clear liquid at the downcomer entrance. Some people tell me that above 0.13 m/s (200 gal/ft2) the downcomer will choke, but the literature presents values of 0.17 - 0.18 m/s (250 - 270 gal/ft2).
I have the feeling that de value of 0.13 m/s is for a new design, not for a revamp...
Can anybody help me?
RE: DOWNCOMER CHOKE FLOODING
Also check the residence time. You need 3 to 4 seconds for the bubbles to collapse before the liquid enters the lower tray. I like to be conservative here and if possible I would go for >5 seconds.
regards
Katmar
A great way to check out your column performance against any model numbers you might generate is to increase the reflux ratio until the column begins to flood.
The total height of a liquid in the downcomer depends on a series of factors:
- The departing velocity onto the tray below as affected by
the clearance under the DC.
- The crest of the liquid over the oulet weir.
- The weir height.
- The ratio of top to botttom area for a sloped DC.
- The drop in pressure of the vapor flowing through the
tray dumping liquid into the downcomer, which frequently
represents about 50% of the liquid height.
- Bubbling area and residence time, froth or foam, as
mentioned by Katmar, may represent an aeration factor of
50%, doubling, in fact the liquid height.
- Small downcomer top area: for clean services a cross-
sectional area of 150 GPM/ft2 of top area
(~0.1 m/s) has been mentioned as a reasonable ROT for
most services.
- Operating pressures. These may influence the V/L
separation due to the proximity of the V/L densities.
- The thermophysical and chemical properties of the fluids
that may affect surface tension, viscosity, etc.,
directly affecting V/L separation.
Have a look at Chapters 6 and 14 in DISTILLATION-OPERATION- by Henry Z. Kister (McGraw-Hill) for layouts of DC and trays and tips to avoid flooding.
