3Com Total Control Access server Please help DanielH or somebody
hello,
I have been trying to configure a 3Com total control Access server.The modems(Quad v.34 Dual STD Analogue/Digital aren't responding or answering to the rings.What may be the problem and how do I resolve it.
I have set the Dip swithes 3,5,8 to the on position. I am running the modems with the edgeserver pro.Can you please help?
Thank you
Thank you
RE: 3Com Total Control Access server Please help DanielH or somebody
Have you checked for IRQ conflicts etc? If the latest drivers aren't working, I suggest you give 3Com a ring...
use this command :
LIST CHASSIS
the result will be like this :
Slot Owner Description Ports Type Console
1 YES 30 Channel High Density Modem 30 DYNAMIC YES
2 YES 30 Channel High Density Modem 30 DYNAMIC YES
3 NO Gen. 2 V.34 Anal-Digi Modem NAC DYNAMIC NO
if the colomn owner is no yes for your modem cards no one will answeer and you have to change the owner state by using this command :
SET CHASSIS SLOT 1 OWNER YES
I hope this help you .
regards
Alaa Musa
