Residence Time - Incidents
Have there been any incidents in which lack of adequate residence time (surge or hold-up time) in a vessel was a contributing factor or the cause?
RE: Residence Time - Incidents
Dear JWS,
Though your question is a general one,for you didn't specify the (INCIDENT  ,or mal operation,or Off specification)..
The function of any surge or hold up drum,tank,or vessel is to allow enough time for ,separation of phases e.g gases and water from crude oil or  naphtha stream for further processing..etc..
A good residence time will ensure,an on spec.feed stream..
Too hort residence time,will give you an off spec product..
Whereas too long residence time ,will make the vessel to large and uneconomical..
These are only examples,coming to mind..if you have a specific design problem..let me know.
Waiel Hasan
