Hidden Sketches
Hidden Sketches
Is there a config.pro setting that will prevent sketched features that are subsequently being used to create surface/solid geometry from automatically being hidden? I have searched through the config.pro search facilities (and the excellent Proesite.com Config.pro Option Search Utility) and found no obvious parameters. Thanks in advance.
Best regards,
Matthew Ian Loew
RE: Hidden Sketches
I have given you a link to show all the config.pro settings including hidden ones. You may already been aware of it.
http://www.proesite.com/UTIL/2001_allopt.htm
The only setting that may help you is SKETCHER_DISP_KNOWN_ENTS which is hidden. I have not tested this parameter, hope it works.
Tofflemire
RE: Hidden Sketches
Thanks, but that is a link to the same site I linked into my post. I am using WF2.0, BTW.
Best regards,
Matthew Ian Loew
