Plywood diaphragm legth for nailing requirements
Thank you in advance for the wisdom. If you have a 6/12 wood truss spanning the N-S direction, would you use the flat horizontal dimension from end to end or the 6/12 top chord horizontal lengths to calculate the required nailing for the diaphragm shear force for the length available to resist the load?
RE: Plywood diaphragm legth for nailing requirements
DaveAtkins
