Redefining Block with AutoLisp
How can I use Autolisp do a block replace (redefine). I am running AutoCAD 2002.
Here's what I want to do. Pick a block (check to see if it is a block) then reinstall the block to redefine it.
I am not very fluent in AutoLisp. So, I am not sure if it can be done. How would the program reinsert the block without using the block reference that is already present?
RE: Redefining Block with AutoLisp
I think you are looking for a command like this:
INSERT BlockName=FileName" "Y" "0,0" "1" "1"
When you insert a drawing with the same name as an existing block, it asks you if you want to redefine the block.  You respond Yes, then give the insertion point and scale factors.
