Sonic? welding mild steel to aluminum plate
There is a company somewhere that uses an israli designed process to sonicly and/or pressure-vibrate un-weldable materials together such as mild steel to aluminum. I have a sample sitting on my desk. Does anyone know if anyone is selling the equipment? What will it weld? Can you buy pre-welded bar stock to use at joints between steel and aluminum plates to weld to?
RE: Sonic? welding mild steel to aluminum plate
The connectors.
http://www.highenergymetals.com/ground_straps.htm
Plate and bar.
http
There is another process of coextrusion of al and steel but my references are no good anymore.
