How to set up gear conection in ProE
This may have already been asked. But a search didn't turn up anything.
Does anyone know of an example on the web or can tell me how to do gear conections. I am using Pro/E 2001. Can it be done? I have done some roller bearings and it sure looks like they have the right rotation. All I used there was a Pin conection.
I figured that maybe contact was all that was needed. I tried seting up two cylanders in contact (0 clearance) several type of rotating conection on both. A driver on one doen't make the other turn.
Will it work if I put touth profiles on the cylander and mesh them together?
Andy
Andy
RE: How to set up gear conection in ProE
The best workaround that I can think of is to assign motors to each of the rotating axes so that they move proportionally to one another during kinematic analysis. It won't let you drag the gears and watch them move in sync. This will let you make a movie, though.
Modeling contact (cams) on the tooth profiles would take forever to do and will take a very good computer a very very long time to compute. Mechanism design in Pro/E isn't made for that kind of simulation... This won't work at all if you have gear teeth that are curved in two directions (like helical or worm gears).
Right now I am trying to do a resolver mechanism that will control phase relations between two crank shafts. It's a variable clearance steam engine design.
Looks like I will have to go to wildfire. Darn I have a lot of parts and assemblies already done. From what I see in other posts I wont be able to load them in wildfire.
You should find Wildfire much easier to use than 2001 as well.
Cheers
Mark
