Simple amperage requirement calculations
Hello all, I am currently building a cabnet that has quite a few eletrical devices built into it (computer monitors, computers, Plasma screen) And it has been a along while since I got through the one electrial subject at uni :) So I am having trouble remembering how to work out how many amps the system will draw, The information I can get off most of the gear is the watts rating.. how can I determine the amps from this info.. also, if using 10 amp cable would it be safe to limit the current in each cable to about 8 amps?
Cheers
Cheers
RE: Simple amperage requirement calculations
Why don't you use a commercial multi-receptacle strip instead of running individual wiring?
