what is E for steel?
Am apprentice at college,need the E for HNC
RE: what is E for steel?
Can you write me the meaning of HNC?
(Normaly the E is 200 000 - 210 000 MPa for steel.)
Irwin
E- Modulus of "E"lasticity is usually taken as 30X10^6 psi (30,000,000 psi) and can vary anywhere from 28.5X10^6 to 30X10^6 psi depending on the type of steel.
The above answers are good ball park numbers. If you have a particular grade of steel, check the following online site for more definite numbers:
http://www.matweb.com/
They also have many more material properties for thousands of materials.
