Aluminum, Laser Welding versus Dip Brazing
I need to convince a customer that a laser welded joint is as strong as or stronger than a dip brazed joint. We are joining two aluminum parts and I have flexability in terms of the alloys depending on which method is used. Does anyone know of any documentation comparing brazing versus welding for aluminum?
RE: Aluminum, Laser Welding versus Dip Brazing
Perform some tensile tests and destructive examination to answer the question, which process would be better.
