EVALUATE function
EVALUATE function
EVALUATE function
This is a spinoff question from Thread770-113109
What is the evaluate function?  It is not described in help.  Can you provide an example of it's useage. I could not get it to work no matter what kind of datatype I fed it.
RE: EVALUATE function
The Evaluate function allows you do dynamically build a string, which is a mathematical forumla.  The Evaluation function then allows you to run that function so to speak, something like the following:
dim TheFormula as String
TheFormula = "SQR(x^2+y^2)"
Result = Evaluate(TheFormula)
Good Luck
As a circle of light increases so does the circumference of darkness around it. - Albert Einstein
