High iron content in chilled water loop
Is there a type of chemical treatment that can be put into a chilled water loop that will keep iron particulate
<.5um in solution even if it passes through a magnet coil?
RE: High iron content in chilled water loop
Is the magnetic coil a part of the equipment being cooled? What problems are you having with the coil?
The more info relative tot he problem, the better we all think...
BobPE
> Is it new? did you flush?
> Do you have a corrosion ongoing? Do you treat chemically your water?
Kind regards
