Solidworks for tool & die
Any SolidWorks users out there using it for progressive die design?
If so, are you using a prog. die package like 3D QuickPress?
If you aren't using QuickPress, what's your preferred method of generating a strip--using assembly mode with a family of sheet metal parts with various features suppressed, or dropping all the features on the piece part into the design library and modelling the strip layout as a single sheet metal part?
Paul
RE: Solidworks for tool & die
http://www.EsoxRepublic.com-SolidWorks API VB programming help
