400watt HID light fixtures
I recently found 32 amps of load on phase B of a 480v 3phase panel
the puzzling thing is no lights are on nothing seems to be on to create this load
my question is , is it possible the ballasts in the field are drawing this current, even though the other 277v leg is not energized to allow the light fixtures to go on
RE: 400watt HID light fixtures
You stopped making current checks too soon. The next logical step is to test branch-circuit currents. Good luck.
Does your post have anything to do with this thread? If not, start a new one. That way, discussions remain focussed on the subject at hand.
If we learn from our mistakes,
I'm getting a great education!
You seem to be under the mistaken notion that a 277V ballast uses 2 "legs" of 277V current. 277V is derived betwween 1 leg of a 480/277V system and neutral. So what you are asking is not relevant, there is only 1 "hot" leg going into those ballasts.
No go back and follow busbar and rbulsara's advice. You have something drawing power, and if it is only on 1 leg you were correct in suspecting a lighting circuit, but that is not absolute. You need to isolate which branch circuit the drain is happening in and work from there.
"Venditori de oleum-vipera non vigere excordis populi"
