Infinite line
Infinite line
Could you tell me the shortest way to build the infinite line on two PLANES intersection.
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Infinite line
Enough, already.
You can make a datum axis from the intersection of two plane.
Also, in a 3D sketch, you can constrain a line conicident with two planes. This line segment will be finite, but for purposes of adding constraints, it behaves "infinitely".
http://www.EsoxRepublic.com-SolidWorks API VB programming help
RE: Infinite line
I am looking for simple, one click command in SW 2005.
Does it exist?
RE: Infinite line
You can avoid making the axis by constraining the line coincident with 2 planes (2 separate constraints).
