Need a simple, but STRONG reduction drive setup......
Here's the skinny......
13B rotary racing boat engine turns at 5252RPM ONLY!!! Power is adjusted by mapping turbo boost. Need inline(reversible rotation, OK)2:1 speed reduction unit design that can handle 400-500HP@5252RPM. Current units available can only handle about 300HP at the RPM......HELP! Thanks.
RE: Need a simple, but STRONG reduction drive setup......
they make quick change rears for racing (800+hp) and I think they may have something that would work for you
Keep the wheels on the ground
Bob
