Using width and length of a recess as dimensioning datums.
Folks-
I often work with designs where a rectangular panel is mounted to a hole pattern within a rectangular recess.  The rectangular panel is usually carefully sized to closely fit inside the recess when the holes come in at worst-case tolerance conditions.  If I were to use the length and width of the recess as secondary and tertiary datums, would I take all dimensions from the CENTERLINES of those two features?  If this is legal, how would this be handled in inspection? Is this an inspection nightmare?  It seems to me that one could gain bonus tolerances by invoking the positional tolerances when the length and width datums are at MMC.
Tunalover
RE: Using width and length of a recess as dimensioning datums.
Tuna,
I don't think you've given us enough to go on here.
Are the holes in both the panel and the recess clearance holes with a thru fastner and nut on the back, or are the holes in the recess threaded, or something else?
I would suggest not using the center line, as imaginary features do tend to be a pain for inspection.
Imaginary datums are poor practice.  If the length and width are used as datums, the part would be inspected relative to the center planes of the datums, which would not be imaginary.  To DIMENSION to the centerlines of the features will only cloud the issue.
tunalover,
   The easiest way to understand datums is to keep asking yourself how you would mount this thing for inspection.  Datums on the mating part cannot work, especially if it is being fabricated in another shop.
   The problem with dimensioning from centrelines is that your tolerance usually are ambiguous.  This is not the case if you use positional tolerances.
   I see two strategies for dimensioning your panel.
   Apply +0/-something dimensions to the length and width of the panel.  Apply basic dimensions to the clearance holes.  The mount face is datum A.  Datum B is across the width.  Datum C is across the length.  I apply two positional tolerances to the holes.  The first is applied WRT datum A, and it is accurate enough to align the holes with the mating holes.  The second WRT datums A, B and C ensures that the holes are positioned WRT the outline accurately enough that the panel fits into the pocket.  This second tolerance should apply at the MMC of datums B and C.
   Apply basic dimensions to the outline and to the holes.  My basic outline dimensions would be MMC.  Datum A would be the mount face.  Datum B would be one of the holes.  Datum C would be another hole located as far as possible from Datum B.  I would apply one positional tolerance to the holes, assuring alignment with the mating holes.  I would apply a profile tolerance all around the outline.  This would be shown to slop inward because of the MMC dimensions noted above.  ASME Y14.5M-1994 shows how to do this.
   I am sure there are more ways to do this, but one of the above approaches should work.
                                JHG
drawoh-
I didn't ask how to dimension the panel.
One might think that it's possible to use datums assigned to the width and length of the recess in a feature control frame of a positional tolerance controlling the holes at the bottom of the recess.  If one does, then don't the datums pass through the midplanes of the recess?  If that's the case, then doesn't the fundamental requirement that dimensions originate from datums force one to dimension from the centerlines?
Tunalover
tunalover,
   It is hard to discuss the application of datums without the context of how you are going to apply dimensions and tolerances.
   You can apply a datum to a surface such as an edge of your cover.  Alternately, you can apply a datum to a width or length, meaning that the datum applies to a centreline.  According to the ASME standad, this datum feature is subject to size variation, and it is necessary to specify RFS, MMC or LMC.
   If you used the length and width as datums, then dimensions from centrelines with positional tolerances are a logical expression of your design intent and your requirements.  In my second example above with the outline centred on the holes, it still makes sense.  The only thing that messes up centreline dimensions is linear +/- tolerances.
                       JHG
drawoh-
For inspection, how would one establish one of those datums?
Tunalover
How to establish a usable inspection datum from the centerlines of a rectangular opening?
For someone who doesn't know what he's doing, the answer is easy...
Coupla racks on a common pinion, one for X, one for Y, or some a those spear point center finders, two for X, two for Y, etc.
Start talking like that to a gagemaker, he'll just look at you funny.
Mike Halloran
NOT speaking for
DeAngelo Marine Exhaust Inc.
Ft. Lauderdale, FL, USA
As drawoh stated, dimensioning from the centerline of the datum is a logical and appropriate way to approach the problem, provided you DO NOT label the centerline as a datum.  This is a very common, but poor practice.  If you feel you must label the centerline, put "CL" in front of the datum symbol.
tunalover and MikeHalloran,
   Since the length and width datums are applied at MMC, a fixture is fairly easy to make.  You mill out a pocket that defines MMC.  It acts as a NOGO guage on the outline.  When the panel drops into the fixture, you can wiggle it a bit to line up the holes.
   I haven't really thought this one through.  It helps explain why ASME Y14.5M-1994 is so dogmatic about specifying material condition.  Without MMC, MikeHalloran's suggestion about the racks and pinions might be the only way to go.
   My alternate suggestion above was to use two holes as secondary datums.  The fixturing for these is simple.  You mill out a pocket at MMC containing a round dowel pin and a diamond dowel pin.  More pins define the other holes.  The cover must drop into the pocket, over the dowel pins.  You can test the outline LMC with a feeler gauge.
   I was told in my GD&T course that test fixture must use the datums as jigging points.  I am not sure this is absolutely valid.  I ignore the drawing, and I just the part up by its mount face, one edge and one corner.  I carefully measure everything.  Now, I look at the drawing and I see what datums I am supposed to measure everything with respect to.  I have enough information to work out where the datums are and where everything else is.  This _is_ a lot of work.
   Centrelines are not defined anywhere in the ASME standard.  The centreline is fairly obvious on tunalover's plate only until I come along and cut out a piece on either side of the top half.  How there are two feature that might define that centre!
                         JHG
I was being facetious.
At first glance, you don't absolutely have to use the datums as jigging points; the math is just _much_ easier that way.
The other choice is, you are working in an arbitrary coordinate system that may or may not align with any features of the part, and after you measure all the part features relative to your coordinate system, you must then do translations and rotations to convert the measurements to the coordinate system defined by the datums, so that you can interpret whether the features are within the tolerance zones.  Well, okay, a modern CMM can accept a part in any orientation, and you can touch the probe to the part in a few places and tell the machine to measure everything else relative to that.
And that's where the wrench gets jammed in the works.  Suppose the datum features on the part are not perfect?  Say your edges were nibbled with a square punch that was rotated a little from the punch's translation coordinates?  Now you've got stair- steps where there should be a straight line.  Put that part in the CMM, and where do you touch it to establish that line?
That's what they really meant in the GD&T course; the real datum coordinate system is defined not by the imperfect features on the part, but on the complementary set of 'perfect' surfaces on the fixture that unequivocally touch, align, and stabilize the part.
Mike Halloran
NOT speaking for
MikeHalloran,
   Actually, the standard takes all that into account.
   Datum A is defined by the three points of your main surfaces that extend down the furthest.  Not at all coincidentally, these are the points that will make contact with your granite reference block.  The datum B edge is the two points that make contact with your second locating surface.   The tertiary datum is the one point that makes contact with the third locating surface.  Most machining and sheet metal processes create nice straight edges.  If the edges are sloppy, you would have to jig everything as per the standard.
   Yet another issue with a thin sheet metal cover is that datum A is being defined by something that is not rigid.  In situations like this, I have left notes on drawings stating that datum A applies when the panel is compressed flat onto the reference surface.  I could swear that this procedure is called up in the standard somewhere, but I cannot find it at the moment.
                         JHG
drawoh
You said "The centreline is fairly obvious on tunalover's plate only until I come along and cut out a piece on either side of the top half.  H[N]ow there are two feature that might define that centre!"
Since the dimension to which the datum is attached defines only one feature of size, then it doesn't matter how many pieces are cut out of the plate;  the datum is assigned to that dimension only.
ewh-
You said "As drawoh stated, dimensioning from the centerline of the datum is a logical and appropriate way to approach the problem, provided you DO NOT label the centerline as a datum.  This is a very common, but poor practice.  If you feel you must label the centerline, put "CL" in front of the datum symbol."
By Y14.5M, a datum assigned to a length or width BY DEFINITION is the centerplane of that feature.  This necessitates using the centerline does it not?
Tunalover
Tunalover,
  Yes, it does necessitate the use of the center line.  However, that center line is NOT the datum, it is the center line of the datum, and should be labeled as such.  To quote ASME Y14.5m-1994, para 4.3.2 "... The datum feature symbol identifies physical features and shall not be applied to center lines, center planes, or axes except as defined in paras. 4.6.6 and 4.6.7."
  Paras. 4.6.6 and 4.6.7 refer to equalizing datums and datums established from complex or irregular surfaces, neither of which are involved in this situation.
ewh-
I agree that the datum feature symbol may be applied to a width because a width is a physical feature (of size in this case).  Let's be careful about our terminology here.  The feature is inevitably an opening or protrusion.  While the WIDTH is a physical feature, the DATUM (not the datum symbol!) is at the midplane of the feature when it is applied to the width dimension.  In this case, where should dimensions originate?  FROM THE CENTERPLANE (centerline)?
Tunalover
tunalover,
  I agree with you.  My point is that it is improper to label the centerline as a datum.  The centerline is not the datum, the feature is.
tunalover,
   Let us assume you place is rectangular and has four holes, one in each corner.  Everything is symmetric.  We use any of the dimensioning and tolerancing schemes described above.
   The holes can be dimensioned from the centreline, or across the centreline.  I would go for across the centreline, since you have dimensions coming from real features, but I would not reject the other approach if I were checking the drawings.
   In a strict technical sense, a dimension from one edge would not be incorrect.  The primary objection to this practice is that on a drafting board, you could miscalculate the dimension and mess up your design intent.  On 3D CAD, you can force your model to centre the holes, and the numbers come out right.  The GD&T will make sense out of all of it.  Regardless, it is not a good procedure.
                         JHG
drawoh-
I've always taken it as "written in stone" that dimensions must originate from datums.  Is this not strictly true?  It's been a long time since I looked at Y14.5 on this point.
Tunalover
tunalover,
   An advantage of GD&T positional tolerances is that the dimensions do not have to originate from datums.  ASME Y14.5M-1994 does not require it.
   That does not mean that dimensioning from datums is not good practise.  Dimensions from centrelines look ugly to me though.
                      JHG
Are there others out there who concur that dimensions need not originate from datums?
Tunalover
At my current shop, we dimension to centerlines all the time.  It works out okay, because our homemade tubes in exotic alloys are not always perfectly round anyway, and because our standard tolerance zone is plus or minus the width of a dull Sharpie point.
In most other kinds of shops, it would be an issue, because it's hard to hook the jaw of a caliper over a centerline.
Mike Halloran
NOT speaking for
If it is a basic dimension, it must be connected to a datum, either through other basic dimensions, or directly.  Otherwise, you are adding additional tolerances.
Dim the length and width of the rect. Add datums (primary & secondary) to one side of each dim inline with the dims. Basic dim the holes. Inspection will position the holes within center of the part (if that is what you want). Can you attach a pic of the part you are dimensioning? It would make it much clearer to us. thanks
Chris
Sr. Mechanical Designer, CAD
SolidWorks 2005 SP0.1
I was taught never to use a centre line as a datum, if possible use the most critical feature.
If you take a very simple example of a square plate with a hole in one corner, the hole is tightly tied up from two edges that say mate to other parts but the other two edges are in free air.
If you dimension from the hole two sizes have a tight tolerance (hole to edge) but the overall dimensions do not need a tight tolerance.
Now do the same from the centre line, both the overall tolerance of the outside and the tolerance from the centre to the hole need to be incredibly tightly toleranced to ensure that you get what you want, just try this you will see what I mean.
Many hours are wasted trying to achieve something that does not need it.
This of course only works on simple 2D, 3D forms create a whole new set of problems.
All-
I had a conversation this afternoon with Lowell Foster in Minneapolis.  Mr. Foster is one of the pioneers of Y14.5.  He stated that it is best to originate the dimensions from the datums associated with the width and length dimensions.  That is, the primary is the perpendicular datum, the secondary is the length datum (centerplane bisecting the length), and the tertiary the width datum (centerplane bisecting the width).
Guys, this is a VERY COMMON design scenario:
Imagine a rectangular, flange-mounted housing (the lengthwise and widthwise cross-sections look like the cross-section of a hat).  The flanges have mounting holes in them for attaching the enclosure to a flat surface (using holes or studs).  If the the internal length or internal width dimensions are used as secondary and tertiary datums (simulating the fit with what is inside the enclosure!) then the dimensions are taken from the centerplanes (avoiding the term "centerline" here).  Functionally speaking, this is a VERY NATURAL way of dimensioning the holes because, by virtue of the way they are dimensioned, the holes are naturally centered about the midplanes of the housing!  Furthermore, bonus tolerances can be granted when these features of size come in at MMC!  That is, the pattern of holes can be allowed more float when the internal length and internal width are the greatest!
Tunalover
good one tunalover
Chris
SolidWorks 05 SP0.1 / PDMWorks 05
ctopher's home site
When in doubt, go to the source!  It's hard to argue with Mr Foster!
My observation is that the description of 'primary is perpendicular datum' should be the 'primary datum feature would be one of the surfaces of the panel'.  The choice of secondary datum feature should be the slot dimesnsion having the greater length and therefore providing a more stable or definitive portion of the feature.  The tertiary would then be the other, or the smaller of the two features.  Not sure if Mr F. Stated thusly or not.
ringman-
You're right that USUALLY one would want to use the length (the greatest dimension of the two) as the secondary.
Tunalover
