creating holes in the assy workbench
I am currently working on an assembly with quite a few parts that need to be mounted to the main baseplate. I try to create the screw holes by using the hole command in the assembly workbench and it tells be to pick a plane or face, but it will not pick anything and nothing happens.
I jumped on my coworkers machine and I was able to create the holes on his machine.
Do I have a setting that is turned off or somthing? Does anybody know how to fix my problem? If so please reply I would appreciate any help that you could offer.
thanks.
thanks.
RE: creating holes in the assy workbench
Most of our problem like that one are solved by cleaning CATSettings...
Eric N.
thanks for the info. I don't wan't to sound like a idiot, but how do I go by doing that?
They may by on your company network.
Run a search for "CATSettings." Delete everything in the folder. Open CATIA, and the default settings (either out-of-the-box or the global settings your administrator has configured) will be restored.
1. In the assembly mode, double click the partA (which u want to create holes), the screen will bring u to Part design or GSD mode, depend on the geometry. The tree will come up.
2. Right click the PartA in the tree, and a side window will pop up, then choose "DEFINE In Work Object". A underline will appear below PartA in the tree. It mean partA become a current partbody for u to edit or create new geometry
3. When u save in the assembly mode, the catpart will be updated at the same time.
Hv fun
Johnny
If you get into external reference problem, try to change the option setting like the link below.
http://ww
Hv fun
Johnny
