Welding after hydrotest
Would it be permissible to weld non pressure parts to the interior of a vessel after hydro testing when not subject to PWHT?
I know that UG- 99 a.1 indicates that all fabrication should be complete before hydrotesting, but does this not apply only to pressure envelope?
Thanks for any information
RE: Welding after hydrotest
If you are adding trim that is not welded directly to the vessel wall, this can be done with approval from the AI.
Why do you think AI should be consulted for this?
Only reason i could think is, this additional attachment may affect structural integrity of vessel. Just curious.
Thanks.
Why not ask? Keep yourself out of trouble.It may be simple as a phone call. If this does not take place it raises questions about your entire program. Do audits and hold points ring a bell?
Remember who the last guy to sign the Data Report is.
GB
