CONVERT 3D AUTOCAD 2000 MODEL TO SOLID EDGE
How do I convert a autocad 2000 3D model (.dwg) to a part or assembly file in Solid Edge V16.
thanks
Matt
thanks
Matt
RE: CONVERT 3D AUTOCAD 2000 MODEL TO SOLID EDGE
"Fixed in the next release" should replace "Product First" as the PTC slogan.
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
Is there an export as SAT (ACIS) option ?
If so you should be able to import this format into Solid Edge.
If you don't have any of these options I don't think you will be able to export your 3D to Solid Edge, as it only imports dwg and dxf formats into 2D.
Try opening your dwg 3D using a dft (2D) template. You might get an empty draft. Close it without saving. Then check in the folder where the dwg is and see if there is a new *.sat file that SE created.
If that's the case, open that file using a par template.
Fred
