Configurations and equations
Let's say I have 3 configurations (A,B,C) of a part. All these 3 configs are used in an assembly. I want Config B and Config C to be 2 and 3 times respectively the size of A. How can I do this?
Thanks to all.
Thanks to all.
RE: Configurations and equations
If you are familiar with excel and how equations are written there you should have no problem writing an equation in solidworks.
mkmech,
what version and SP are you using?
Best Regards,
Jon
Challenges are what makes life interesting; overcoming them is what makes life meaningful.
wouldn't a design table do what you need?
Yes, you could also use the Scale feature & suppress/unsuppress it for each config, but you would still have to set it manually.
Depends on how you want the parts to interact.
If you always want parts B and C to always be 2 and 3 times larger than A then a design table is a good start. But for the parts to have some logic behind them an equation will always keep the parts B and C 2 and 3 times larger than A.
Rather than typing it in manually every time into the design table for each configuration you could have a couple of equations that look like the one below
B distance = (A distance)*2
C distance = (A distance)*3
with the equations being typed in as above A will be the driving part. So what ever A's distance is B and C will always remain 2 and 3 times larger.
Does this explain things?
Best Regards,
Jon
The "help" will help explain the callouts in a DT.
Scott Baugh, CSWP
3DVision Technologies
www.3dvisiontech.com
www.scottjbaugh.com
FAQ731-376
FAQ559-716 - SW Fora Users
You can have that same equation in a DT as well.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
I realized that after I typed that post.
Thanks though.
Best Regards,
Jon
