Ordinate dimension offset
Is there any way to change the default value for the first ordinate dimension from zero to some value that will carry through the rest of the dimesions. I need to insert a datum elevation other than zero on some equipment and then show the subsequent elevations without having to go in and edit the dim text.
TAP
TAP
RE: Ordinate dimension offset
Scott Baugh, CSWP
3DVision Technologies
www.3dvisiontech.com
www.scottjbaugh.com
FAQ731-376
FAQ559-716 - SW Fora Users
