hatch problems
hatch problems
I have sectioned through a tube that has a small tube welded inside it as a plain bearing housing. As this is a single part it is modeled as a part eventhough it is manufactured as a weldment.
To show that it is two parts I have drawn lines in the section view. I have also drawn a small triangle that shows where the weld will be.
The trouble I am having is that I cannot hatch the trialgle on the section view. I can select it as a boundary but it wont hatch.
Please help.
Please help.
RE: hatch problems
I'm doing this at the drawing level.
Scott Baugh, CSWP
3DVision Technologies
www.3dvisiontech.com
www.scottjbaugh.com
FAQ731-376
FAQ559-716 - SW Fora Users
RE: hatch problems
The next problem is that I cannot select both triangles.
When I draw them outside the drawing view it all works, drag them into the view and it disappears.
RE: hatch problems
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
RE: hatch problems
RE: hatch problems
If it isn't you may have to upgrade your card. I had a similar experience in a early version of solidworks. The problem was the video card.
Best Regards,
Jon
Challenges are what makes life interesting; overcoming them is what makes life meaningful.
