RAM Limitation
RAM Limitation
I know there are some other posts that have made reference to this, but I"m wondering if there's anyone out there who has had this problem.
One of designers is trying to open a file, and RAM usage peaks at just under 1GB.
Computer Specs:
Windows XP SP1
<BOLD>2GB RAM</BOLD>
P4 2.0Ghz
NVidia Quadro4 700
40GB HD
We've tried enabling 3GB mode and changing the Virtual Memory size, to no avail.
Thanks in advance!
Computer Specs:
Windows XP SP1
P4 2.0Ghz
NVidia Quadro4 700
40GB HD
Thanks in advance!
RE: RAM Limitation
Other than those items, do you see anything in the Task Manager sucking up RAM beyond normal that would push your RAM back down to 1GB?
Jeff Mowry
www.industrialdesignhaus.com
Reality is no respecter of good intentions.
RE: RAM Limitation
Have you opened the file on another machine? If so, does it treat the RAM differently?
Jeff Mowry
RE: RAM Limitation
You may have a bad RAM module. Check that your computer is actually recognizing the 2GB of RAM. If it isn't try removing & reseating your RAM sticks.
RE: RAM Limitation
Check the IMPORTANT NOTE ABOUT WINDOWS XP SERVICE PACK 1 warning at http://ww
RE: RAM Limitation
System Spec:
xp pro ver. 2002 sp 2
1.00 GB of RAM
RADEON 9200 - 128 MB
RE: RAM Limitation
Total pages file size for all drives: 1536 MB
Virual Memory
Initial Size (MB): 1536
Maximum Size (MB): 3072
c: 1536 - 3072
Can I make any adjustment to these numbers?.
RE: RAM Limitation
RE: RAM Limitation
RE: RAM Limitation
Open the Control Panel, hit Performance and Maintenance, then System, then the Advanced tab. Under the Performance item, click Settings, then the Advanced tab, then Change for the virtual memory settings.
Jeff Mowry
