Opamp replacement: JRC 9003
I haven't been able to find a datasheet or even a pinout anywhere in the web. JRC hasn't responded so far either.
It supposedly is a dual opamp with single supply. It is from a Marantz amplifier.
Can aybody help?
RE: Opamp replacement: JRC 9003
I wonder if the "9003" is a date code (1990 March).
For the pin-out, assuming that the pin-count is reasonably low, can you examing the amplifer PCB to derive the IC's pin-out ?  That's how I would start...
Also, look for the amplifier's schematic or service manual on-line somewhere.  Such info might help with the IC.
Ok guys,
i had another look at the device and of course i was looking for the wrong code - it is a NJM2041 Type. With that code i easily could find the datasheet.
Blinded by the obvious again ... thanks to all for setting me straight on this one.
