Is it possible to pattern this
I have this sample file. I'm trying to pattern the block seen on the left side all around the green part. Is this doable? Thanks.
[img
[img
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Is it possible to pattern this
It looks like you have a Multi-bodied part. So all you have to do is select the linear pattern and instead of selecting features you need to expand the option to "select bodies" instead. Of course when selecting linear pattern you also have to give it a direction to pattern along. This can be done by selecting a given edge from one of the other bodies in the part.
Hope this helps.
Best Regards,
Jon
Challenges are what makes life interesting; overcoming them is what makes life meaningful.
Do you want to create a feature that connects the two gray blocks that follows the green part? Or do you wnat to create instances of the block on the left that is below the green part?
I think you need to clairify what you want your end result to be.
Best Regards,
Jon
http://us.
Jason Capriotti
Smith & Nephew, Inc.
Scott Baugh, CSWP
3DVision Technologies
www.3dvisiontech.com
www.scottjbaugh.com
FAQ731-376
FAQ559-716 - SW Fora Users
http:/
Jeff Mowry
www.industrialdesignhaus.com
Reality is no respecter of good intentions.
The errror message I get is:-
Theophilus, how can you do it in Assy mode effeciently?
If you want to use a pattern, you can drive the pattern in a variety of ways, such as a linear, circular or curve-driven or sketch-driven pattern, like MElam posted.
Jeff Mowry
