Cost/Benefit of Multi Engine Vehicles
Reciprocating engines for motor vehicles still cost > $10/kW so it will be awhile before fuel costs make multi-engine vehicles economical, assuming it will ever happen.
DOE or DOT has some regulations ready to go to require semi rigs to have APUs (aux. power units) because tractors waste billions in fuel idling. All DOT needs to do is find some people willing to enforce the regs., i. e., show up at truck stops at 2 am to bang on the cab doors of violators.
While sitting in traffic near Malfunction Junction I thought it might be good to have a small "trolling" motor in every vehicle to save gas. A lawnmower engine will move most vehicles fast enough for Capital Beltway and LA traffic.
With hybrids it is possible to swap out engines. You could have a big one for towing the boat on weekends and a smaller one for commuting.
Bret Cahill
Bret Cahill
RE: Cost/Benefit of Multi Engine Vehicles
The car had several unpleasant characteristics:
The worst was that at certain speeds there was some sort of resonance between the two engines that was shockingly loud.
The second was that the anti dive didn't work out too well in the rear when braking. That was later corrected.
Driving with only one engine running was suprisingly sluggish.
The fuel consumption was severe.
The heavy spring on the accelerator pedal to manage both engines got old quickly in traffic.
All that said, the four wheel burnouts were pricless for an 18 year old.
Jonathan T. Schmidt
http://www.schmidtmotorworks.com
Here's a company trying to put a two cylinder gasoline APU in the back of SUVs:
h
Terry
The larger engine would only spin at one speed and would require something like a torque converter or other fluid coupling transmission. The energy wasted getting up to speed wouldn't be such a big deal on the interstate but it might be a problem in traffic.
Large (50 MW) aircraft GT engines typically have 70 times more power/weight than vehicle reciprocating engines. Even if the smaller GT engines had only 3 - 5 times more power / weight of reciprocating it would make sense to stuff two or more under the hood.
Assuming, of course, they were cheap enough to make good economic sense.
Bret Cahill
I think your prices are whack, OEM gasoline engines run about $10/kW, for cheap ones. I doubt a diesel would be thrice that. The cost/weight tradeoff for cars is completely different than for aircraft.
Cheers
Greg Locock
Jonathan T. Schmidt
Nevertheless, the GE example may encourage efficiency increases in smaller gas turbine engines, lower economies of scale and lower Reynolds numbers not withstanding.
Wankels may be compact enough to stuff two under the hood.
The problem is, if the smaller engine is going to be prime prime mover as in a series hybrid, then you really want it to be the clean and efficient engine, which works against small engines.
Bret Cahill
As far as PRACTICAL prime movers are concerned, consider the following:
CI recip piston engines are the best choice efficiency-wise.
Recip piston engines are the best choice cost-wise.
Turbine engines are the best choice power-to-weight wise.
However, emissions-wise, turbine engines can be pretty good:
http:
http://
Terry
I have been looking for a plot of power delivered to the wheels for acceleration and available for regenerative braking of a car or truck during a city driving cycle to estimate the possible savings. In the last 2 years I have not found such information.
My estimate is it is possible to reduce fuel use by 50% is some cases.
Braking is much more difficult. Your best bet would be to talk to someone with an electric car and instrument their battery.
Here's some approximate stats
almost all braking is at 0.35g or less
average braking is 0.2g
If you contact Peter, he has electric car data for real world driving, http://people.unisa.edu.au/Peter.Pudney
Cheers
Greg Locock
The real world experience that GM got from running the Impact program would probably make them the best source of information like that, sadly the rest of us are unlikely to see it.
Incidentally you would probably be able to start generating your own data if you have an OBDII scanner, using vehicle speed to work out the decel rate, and "brakes on" to activate it.
Cheers
Greg Locock
I took a snap shot of the data and up to about 20 MPH the vehicle only puts about 2hp to the ground during acceleration. (For those how have not seen the data the engine is listed at 22075 W, or 75,320 BTU’s at this snap shot) If that is converted to BTU’s that is only 5091 BTU/hr, or .037 gallons per hour at 100% efficiency, or 540 mpg on diesel. This does not seem possible.
This is why I would like better data.
My preferred method would be to measure torque and rpm at the drive wheels.
Thanks, Ed Danzer
