12L14 too hard
12L14 too hard
I have small parts made from 12L14 cold drawn with hardness about 90HRB. What can I do to soften the material which will be deformed to a lower height.
Would heat treatment be influenced by the lead from the material?
Thanks a lot for your help.
RE: 12L14 too hard
RE: 12L14 too hard
RE: 12L14 too hard
RE: 12L14 too hard
1) Are you testing the lubricant and therefore do not care if the ring develops cracks? 1/2 height is severe deformation and cracks would seem a distinct possiblility given swall's comment even though this is a very ductile alloy.
2) The Lead will not have much effect on heat treatment.
3) You could try stanweld's suggestion at about 1200-1250F but you might need to perform a full anneal at about 1650F and furnace cool for dead soft.
