Settle-out pressure
Settle-out pressure
Settle-out pressure
What is the meaning of settle-out pressure for a compressor and how is it calculated
RE: Settle-out pressure
What will be the resulting pressure of the "compressor segment" (that is from downstream ESDV to upstream ESDV) if the compressor shuts down while in normal operation (do not make any sepcial allowances for check valves)?
Find the volume of all upstream and downstream piping and use thermodynamics to calculate the settle-out pressure.
Best regards
Morten
Thank you Morten, for your quick and valuable reply.
API RP 521, 1997, Appendix B details the calculation of Settling out Pressure.
HAZOP at www.curryhydrocarbons.ca
