Simple maths
Simple maths
Simple maths
I am trying to simplify the following
[(1/x)]-x
into a single variable of x i.e.:
[(1/x)]-x = ?x?
Any ideas?  (This is for my work and is NOT a school homework question.)
Cheers,
-- drej --
RE: Simple maths
(Hope the symbols work out OK !)
[(1/x)]-x = (xe-1)e-x = xex or x to the power x
QED
RE: Simple maths
Thanks, Yates.
Cheers,
-- drej --
RE: Simple maths
You don't need "e" for that- just use the definition of a negative exponent.  Assuming, of course, that the "-x" is an exponent, which is not real clear in the post.
RE: Simple maths
Normally ^ is used to indicate an exponent.
Thus:
[(1/x)]-x=(1/x)^-x  ????
RE: Simple maths
x^x
RE: Simple maths
Or xx
That's x[sup]x[/sup]
Good Luck
johnwm
________________________________________________________
To get the best from these forums read FAQ731-376 before posting
UK steam enthusiasts: www.essexsteam.co.uk
RE: Simple maths
The equation reads:
[(the inverse of x)] - x
or
  1
 ---  -  x
  x
This is clearly shown by the square brackets.
RE: Simple maths
The square brackets are redundant, which is why everyone got confused.
For your updated definition, what exactly are you looking for?  The only other plausible output is:
(1-x2)/x
Not sure if that's any simpler
TTFN
RE: Simple maths
Drej- Then try this....
(1/x)-x = ?
    to
(1/x) = x
   so
1/x = x
Thus:
x=1.
There is only a point solution to this equation. And I'm wondering what sort of engineer cant do algebra.
RE: Simple maths
Yeah, symbolic logic needs to be addressed as correctly pointed out above.  The exponent is typically listed like x^2 for the square of x, so buddy got it right 1/x minus x on the left hand side.  I assume equal x on the right hand side?  Whatever.
This seems simplistic, multiply through both sides by x to clear the inverse and get:
                    1 - x^2 = x^2
to which adding x^2 to both sides would ultimately result:
                    1 = 2 x^2
I would get x = sqrt(1/2) = +/- 0.70711.
This assumes that you need (1/x) - x = x, perhaps a very big assumption.
Kenneth J Hueston, PEng
Principal
Sturni-Hueston Engineering Inc
Edmonton, Alberta Canada
RE: Simple maths
Nick - be careful with "wise-crack" answers - since when is
(1/x)-x = ?  equivalent to (1/x)-x = 0?  Only when ?=0, right?
RE: Simple maths
ivymike- yep you're right. I should not have made that last remark.
I hereby apologize to anyone I've offended. Esp. Drej, because I didn't do any better with my substitution of 0 for ?.
As da Cockroach states there is another interpretation.. It's still just algebra though...
RE: Simple maths
some other equivalent expressions:
-(x+1)(x-1)/x
(1-x^2)/x  (as mentioned above)
RE: Simple maths
Drei,
{1/x}-x is not an equation; it is simply an expression.
What is wrong with 1/x-x?
Do you want another?
(1-x^2)/x
If you think that simplifies the expression, then go for it.
