Combine numbers
Combine numbers
I have several columns of numbers in my Excel spreadsheet like so:
80 500 2 35
80 535 3 21
Can anyone tell me how I can combine the numbers for one row and place them at the end column to form the number in this format 80-500-2-35?
Cheers for any help.
-- drej --
80 500 2 35
80 535 3 21
-- drej --
RE: Combine numbers
A1 = 80
B1 = 500
C1 = 2
D1 = 35
Then you can concatenate them together in E1 with the following formula:
CODE
Good Luck
As a circle of light increases so does the circumference of darkness around it. - Albert Einstein
RE: Combine numbers
